Deni Posted April 7, 2004 Report Posted April 7, 2004 I've built the cell phone indicator, but i have some probs :-[ First I used a BAT86 instead of the BAT46 which i suggested, they didn't had anything else alike in the store is that a usable diode fo rthis circuit? When I turned the power on I did 5V the diode lit constantly, it seemes that the current just passes through D1 and the led from + to -. When I turned the power down to 1.5V the diode didn't lit anymore but it didnt flashed either near a ringing phone. What could I have done wrong? :'( Quote
MP Posted April 7, 2004 Report Posted April 7, 2004 Here is a comparison of the data sheet specs. These diodes have some differences. Have you checked to make sure all of you components are oriented correctly? I have not built this project, so I do not know the specs on it. I suggest that you check the parameters of the data sheet with the component used. Did you have trouble finding the correct component?MP Quote
Deni Posted April 8, 2004 Author Report Posted April 8, 2004 I only had problems finding the diode, I used a 10mH as L1 becase I want to make the whole thing on a small board. When I remove D1 the led stops liting and thats kinda obvious. But [glow=red,2,300] CAN [/glow] I use that diode instead? Quote
