Jump to content
Electronics-Lab.com Community
TV Signal Amplifier circuit
speddmon
Please help. I am curious about some of the components in this circuit. They are in particular L1 and L2. The circuit description says nothing about them but this, L1 and L1 Diameter: 5mm / Wire: 0.5mm / Spiral: 8. If anybody knows anything about this please inform me. Also, I would like to know which resistor I can swap with a pot to make it a variable gain amp rather than the fixed 20db?? Thanks in advance.
Link to comment
Share on other sites
L2 resonates with C5 and C4 near the center of the TV band. A 75 ohm resistor would probably work as well. L1 is a "peaking coil". It is self resonant near the upper edge of the band and is there to raise the high frequency gain. You cannot put a pot in this circuit because the leads have to be very short and this is a high frequency circuit. The ratio of C5, C4 could be changed, keeping the total constant, to change the gain. FYI: the total is (c5*c4)/(c4+c5).
Link to comment
  • 2 months later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
