equinox Posted April 14, 2004 Report Share Posted April 14, 2004 hi! anyone could help me this project... Quote Link to comment Share on other sites More sharing options...
MP Posted April 14, 2004 Report Share Posted April 14, 2004 There are a lot of methods for temperature control. Surely you have something in mind already. How did you want to go about this? Let us know something about the hatchery and the temperatures you need. I assume it is only for heat and there is no need for cooling? What is the source of the heat? How is it switched on and off? What voltage will you be switching on and off?MP Quote Link to comment Share on other sites More sharing options...
equinox Posted April 14, 2004 Author Report Share Posted April 14, 2004 temperature ranges between 23-25 degrees celius. my project is applied in the african hito hatchery. and the problem is that the water is flowing.. water source is deep well and temperature of the water varies the climate. Quote Link to comment Share on other sites More sharing options...
MP Posted April 14, 2004 Report Share Posted April 14, 2004 Here are some links that might get you started.http://www.myplace.nu/avr/thermo/http://electronickits.com/kit/complete/meas/ck108sc.pdfhttp://www.discovercircuits.com/T/temp-cont.htmMP Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted April 22, 2004 Report Share Posted April 22, 2004 This is a Low tech solution. Run the water into a clear plastic covered pond and let it stand for a while. The sun will warm it up. Then use a temperature controller to monitor the water and release the colder water while introducing the warmer water untill the desired temperature is aquired. Quote Link to comment Share on other sites More sharing options...
