Jump to content
Electronics-Lab.com Community
12 volts led power input indicator circuit
mixos
This simple circiut setup, is what i use to indicate 12 volts dc into all my circiuts, even the high voltage circiuts. and for 24 volts input change the resistor to 1.2k . faceing the rear of the togle switch the togle at the front is switched upwards, when wireing up this ,to indicate 12 volts dc to be flowing into your circiut.
by Steven
Link to comment
Share on other sites
  • 3 weeks later...
Hotwaterwizard,
If the capacitor is discharged, and you apply power at the time that the AC voltage is at its peak of 170V, the LED must pass 1.7A for a moment. If you turn-off the power when the AC voltage is at its peak of one polarity, then while the capacitor is charged, apply the power when the AC voltage is at the other polarity, 3.4A!
Can an LED withstand such abuse?
Doesn't the LED flicker?
Kevin,
The 12V and 24V circuits also indicate on many other voltages. The resistor limits the current, not voltage.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
