pmontone Posted May 1, 2004 Report Posted May 1, 2004 I have built a power supply using a 25.2v transformer and a LM317T variable voltage regulator. I am using the center tap on the transformer so there is another 12.6v available. My question is how would I add the digital panel meter project on this site into the circuit? Quote
ante Posted May 1, 2004 Report Posted May 1, 2004 Hi pmontone!Which kind of panel meter is you planning to use?Ante ::) Quote
pmontone Posted May 1, 2004 Author Report Posted May 1, 2004 I am planing to use this meter: http://www.electronics-lab.com/projects/test/014/I have taken out one of the digits because my supply will never go about 99.9V Quote
MP Posted May 2, 2004 Report Posted May 2, 2004 pmontone, the output of your power supply would connect also to the input of this project. Then you will have a digital display.There is a conversation about this project that will also give you pointers. You should use the search to find it or follow the link from the project.MP Quote
Guest Posted May 2, 2004 Report Posted May 2, 2004 pmontone, you check out this link. It might help you.http://users.otenet.gr/~athsam/digital_volt_and_ambere_meter_eng.htm Quote
