Kevin Weddle Posted May 16, 2004 Report Share Posted May 16, 2004 When using a small value capacitor, a nonlinear situation exists. The signal quickly charges the capacitor. This creates DC charging for each value of the signal and makes it follow the capacitor charging function. Does anybody follow? Ideally, you want all of the signal without the nonlinear function of the charging capacitor. Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 17, 2004 Report Share Posted May 17, 2004 Kevin,Connect a resistor in series with a capacitor, so that the resistor can charge and discharge the capacitor. Connect a signal to the resistor. You now have a linear low-pass filter, with its output across the capacitor.It doesn't matter that the capacitor charging is exponential instead of linear, unless you need a linear triangle wave or sawtooth.If you feed the low-pass filter with a pure sine wave, then the output will be just as pure (very linear) as the input, except at high frequencies when its output level is reduced and is purer (less distortion and even more linear). Quote Link to comment Share on other sites More sharing options...
Kevin Weddle Posted May 24, 2004 Author Report Share Posted May 24, 2004 You will notice that even a triangle wave is based on the charging curve. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 26, 2004 Report Share Posted May 26, 2004 Are you asking how does a coupling capacitor work between two stages of an amplifier?How is it able to pass the alternating wave through it ? Quote Link to comment Share on other sites More sharing options...
ante Posted May 26, 2004 Report Share Posted May 26, 2004 audioguru,Excuse me, can a triangle wave be linear?Ante ::) Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 27, 2004 Report Share Posted May 27, 2004 Ante,A triangle wave can be extremely linear if you use an integrator that is made from an opamp that has a voltage-gain of 100,000 or more, and use a low frequency.Of course the linearity drops at higher frequencies.Gross linearity error can be seen as a departure from a straight line on a scope. Quote Link to comment Share on other sites More sharing options...
Kevin Weddle Posted May 31, 2004 Author Report Share Posted May 31, 2004 The triangle wave rely's soley on the DC charging of the capacitor. I would tend to use the capacitor and a transistor driven by a square wave to generate a triangle wave. The use of an opamp is not necessary. Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 31, 2004 Report Share Posted May 31, 2004 Kevin,A transistor can produce a very linear ramp if cofigured as a constant current source. But to make a triangle wave you need 2 transistors (1 ramping up, the other ramping down) and a complicated circuit to switch them on and off. An opamp has all those things built-in.You could also use a transistor as an integrator, but linearity would not be as good as an opamp because its gain is no where near as high as an opamp. Quote Link to comment Share on other sites More sharing options...
Kevin Weddle Posted June 2, 2004 Author Report Share Posted June 2, 2004 A square wave applied to a transistor with a capacitor to ground on the collector will produce a charge ramp as well as a discharge ramp. Quote Link to comment Share on other sites More sharing options...
