audioguru Posted May 21, 2004 Report Share Posted May 21, 2004 MP,Thank-you for correcting your original statements. Are you using translation software? Where are your other corrections that I made?I see your point that a relay coil terminal that has a continuous voltage on it could conduct through a path of dirt to ground and latch-on, and that your suggestion of grounding the coil stops this from occuring. But then the dirt or the PNP will blow-up instead.Kasamiko,How are your relay tests? Quote Link to comment Share on other sites More sharing options...
MP Posted May 21, 2004 Report Share Posted May 21, 2004 audioguru, you can argue the point all you want, but what I have offered is a module which is time proven. Not theory. Rhonn can take it or leave it and it would not move me in any way. Suggestions from others seem to annoy you. Or perhaps just suggestions from me ;D. Still annoyed about current storage in a capacitor? ;DNo, I am not using translation software. ( nor did I correct myself ;) ). You are the only person who has had trouble with reading or understanding my English to my knowledge.MP Quote Link to comment Share on other sites More sharing options...
Guest Kasamiko Posted May 22, 2004 Report Share Posted May 22, 2004 OK.OK.Ok... I've found the cause!!!Our line voltage occasionally drop to a VERY LOW VALUE of 185VAC!!! Which starved the whole circuit or disconnect the relay, which make my load turn on and off!! Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 22, 2004 Report Share Posted May 22, 2004 Kasamiko,Congratulations for finding it. We call low line voltage "a brownout" over here. Now you can build an Uninterruptable Power Supply with a nice big inverter inside. When the line drops or fails then the UPS continues the power. Quote Link to comment Share on other sites More sharing options...
MP Posted May 22, 2004 Report Share Posted May 22, 2004 Kasamiko, A line voltage drop down to 185 VAC drops the 12 VDC buss to a level too low to switch the relay? MP Quote Link to comment Share on other sites More sharing options...
Guest Kasamiko Posted May 22, 2004 Report Share Posted May 22, 2004 Kasamiko, A line voltage drop down to 185 VAC drops the 12 VDC buss to a level too low to switch the relay? MPYou're right MP.. ;D Quote Link to comment Share on other sites More sharing options...
