Jump to content
Electronics-Lab.com Community
digital tachometer
baja
Well,
I want to set up the digital tachometer on my bike and I need a formula to calculate the frequency relation to RPM.
I tried with this one Hz=(number of cylinders * RPM/120) but..... ???
The Bike has one cylinder, four strokes and it has two sparks per revolution.
Link to comment
Share on other sites
Hi Ante!
I removed the old battery ignition system and put the flywheel magneto cdi ignition.
This data I picked up from www.aet.si:
Flywheel magneto:
4-pole, rotor diameter 103mm
Triggering:
internal, 2 sparks per revolution
Spark type:
AC arc discharge
Ignition electronic:
C.D.I.
Maybe I have to calc, Hz = 2 * revs
8)
Link to comment
Yep, I got it!! ;D
dig up the formula on the web, which is fairly simple. I have to multiply, pulses/rev*rev/min then divide by 60sec/min and that equals Hz or ignition pulses per second.
In my case; 50Hz is 1500rpm
beauty lies in simple things
Cheers!
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
