Jump to content
Electronics-Lab.com Community
Modification help..
Guest Kasamiko
Guest Kasamiko
I'm planning to construct this circuit:
But will be using a power transistor instead of a BUZ 326 MOSFET.
Anybody can help me modify it??
Thanks!!
Link to comment
Share on other sites
Kasamiko,
The BUZ10 and BUZ11 are rated for only 50V, and 75W.
The 30A BUZ11 is good for a very simple inverter. 300W would be easy from a single pair, directly driven from a 4047. Newer MOSFETs having a higher current rating (with better thermal conductivity) would operate cooler and allow more output.
Hotwaterwizard,
If you simply replace your resistor and zener with a pot to make the output voltage adjustable, then the transistor's base current will fry the pot.
But maybe a darlington transistor will work.
Link to comment
Kasamiko,
I see, you have problems getting components at your place. To find a suitable MOSFET for this purpose I would look in an old PC PSU if you can get your hands on one. Or if you want to have a bipolar BUV 90 is a good choice, common in old TV sets.
Ante ::)
Link to comment
Guest Kasamiko
I've been servicing colored tv's and need a variable power supply to power some tv set under repair..
Yes I know 330VDC is too much.. :o :o
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
