Jump to content
Electronics-Lab.com Community
Yourwins,
The 7812 is a 12V regulator with many transistors and resistors inside. A multimeter cannot measure if it regulates properly, but can tell only if it is shorted. I don't think that it can measure the difference of one that is blown open.
The best way to test it is when it is functioning with a proper input voltage and load.
Link to post
Share on other sites
Guest Kasamiko
I do a quick and dirty check by applying about 15vdc at the input and monitoring the output pin for 12vdc.. ;D
But without a load sometimes will give a false reading that drop when a load is connected..
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
