Jump to content
Electronics-Lab.com Community
Design of DAC
If I want to design a Switched-Capacitor Digital to Analog Converter front-end transmitter for CDMA application, can someone tell me where can I get the information about the design. (like the theory that involved, schematic, etc)
Link to comment
Share on other sites
The idea of a D/A is surrounded by the weighted ladder. Each sequence is able to produce a current that results in a voltage. But I am wary of this opamp configuration because of how it is used. The opamp is meant to operate high gain, even though it will operate as a constant current source. I would be tempted to change the configuration a little. You could probably use a transistor circuit and achieve what you want.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
