Jump to content
Electronics-Lab.com Community
PS1 Car supply
AJB2K3,
Ante's suggestion is a very good one and should work fine. If that part is not available to you, here is a converter circuit that is close. This is only a start and you will have to make some changes. In fact it is a basic building block for a simple step down regulator that can have many purposes if you make the base voltage variable with a pot.
Change the zener diode to allow the voltage you want. R1 determines the base current. V/R=I. The transistor should be one which will allow the current you require. I cannot find a data sheet on the ECG184, but a post on another site gave the description: The ECG184 Power Transistor is a bipolar silicon NPN 4 Amp, 40 Watt power transistor. Another website stated that the ECG185 is rated at twice the power rating. Personally, I would recommend finding transistors that are very common to your geographical area.
Hope this is somewhat helpful.
MP
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
