Jump to content
Electronics-Lab.com Community
signal conversion
A pulse counter will continue to count the pulses indefinitely. Let's say you have a high frequency and the pulses you count are many for a certain duration. So you set the duration with the enable line. You still have a bunch of frequencies that need to be separated so that you have one frequency at the input to the counter. Use a bandpass filter. Amplify the frequency until it becomes a pulse. Now you can count the pulses and determine that you have that frequency. If it's not there, then you won't have any pulses to count. Do this with each frequency you want to make sure is there.
Link to comment
Share on other sites
A bandpass is not a low pass filter. The amplifier will turn the triangle shaped wave of the audio, of a single frequency, into a square wave. Then the pulses can be counted over a given duration set by the enable line. 5 pulses in .5s will give you a frequency. 6 pulses in a given .5s means the filter did not select the correct frequency. 0 pulses in .5s means the frequency is not in the audio. The purpose of this exercise is to know that the audio contains the frequency you have selected.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
