quantum Posted July 15, 2004 Report Share Posted July 15, 2004 This project here, I have multiple questions.http://www.electronics-lab.com/projects/rf/018/index.htmlFirst off, the microphone on the left of the schematic. The V+ I'm assuming, is where the positive terminal of the battery is to be connected indirectly. The ground smbol is for the negative terminal of the battery to connect to the mic. also. My question for you is what are you suppose to do with the input lead of the microphone. Is it just me, or are there some microphones with three leads coming out of them? I am pretty there are not ones like that, of course. I've seen that the input is just the V+. Is that true, or is that pish posh? Another question, what does CB in CB transmitter represents. Quote Link to comment Share on other sites More sharing options...
AVRFreakMan Posted July 16, 2004 Report Share Posted July 16, 2004 This circuit is a CB transmitter, not "reciever"(the correct spelling is "receiver").CB means Citizen's Band.There are microphones that need a small supply voltage(and limited current which is done by the help of the resistor R5) to be able to work(because they have embedded preamplifier). This is why the circuit has this option.For microphones that do not need this, you can just leave it unconnected.Kyriakos Quote Link to comment Share on other sites More sharing options...
quantum Posted July 16, 2004 Author Report Share Posted July 16, 2004 AVRFreakMan, I modifyed it to the correct spelling. Thank you for your knowledge on a limited supply of curent for the mic., thus to put a resistor in series. However, you didn't answer my question on why there is a input lead. Quote Link to comment Share on other sites More sharing options...
AVRFreakMan Posted July 17, 2004 Report Share Posted July 17, 2004 Some microphones have three leads, othes have two leads.One of those leads is surely the ground(or -V or 0V or GND or Common).Both of these two categories might need supply that take from the third lead, if they have three, or from the second(which additionally serves as MIC_OUT), if they have only two.For those with 3 leads, the one that is not the VCC nor the GND, it is the MIC_OUT. Quote Link to comment Share on other sites More sharing options...
