trafo Posted July 28, 2004 Report Share Posted July 28, 2004 I remember twelve years ago a Siemens IC which needed a 7VDC external reference and would detect Mains AC zero crossing point and switch on and off at this point for duty cycle control. I used it for a fan speed controller. I would like very much to identify this IC and application note. The benefit was no RFI at all and very stable control. Please help if you can. Thank you. Quote Link to comment Share on other sites More sharing options...
ante Posted July 28, 2004 Report Share Posted July 28, 2004 Trafo,Welcome to this forum.Is it a Solid State Relay you are looking for or just an IC?Ante ::) Quote Link to comment Share on other sites More sharing options...
trafo Posted July 28, 2004 Author Report Share Posted July 28, 2004 Thank you for the welcome and the interest. I was looking for a Siemens IC that would trigger a triac at zero crossing point of the mains supply to control the duty cycle of the AC 230V mains for speed control of a fan or other load without generating any RFI. This particular IC was an elegant solution even though it required a tiny Xformer to give it a 7VDC reference. If there is a more suitable solution with a low parts count that will achieve the same purpose, I will be happy to consider it. Thank you again.Trafo Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted July 28, 2004 Report Share Posted July 28, 2004 Need more Info! Quote Link to comment Share on other sites More sharing options...
trafo Posted July 28, 2004 Author Report Share Posted July 28, 2004 OK. I live in a tropical climate where we use ceiling fans quite a lot to keep cool. The old controllers were heavy autotransformers with multiple tappings and a rotary switch to select your voltage to drive the fan. Now with rising material cost and the cheaply available light dimmer, that's what is being supplied with fans. Trouble is that these generate a good deal of RFI. I had made one controller with the Siemens IC that controlled the duty cycle of the triac which controlled the fan speed and left it in a house I once inhabited. I would like to be able do this again. I would prefer to use a twelve way rotary switch to select fan speed.Thank you for your interest.Trafo Quote Link to comment Share on other sites More sharing options...
ante Posted July 28, 2004 Report Share Posted July 28, 2004 Trafo,I don Quote Link to comment Share on other sites More sharing options...
trafo Posted July 28, 2004 Author Report Share Posted July 28, 2004 Ante,I thank you again. I have looked at the Motorola device and want to say that the Siemens device did this - perhaps without opto-isolator - but it also provided the duty cycle timing drive to the triac.I wish I had the circuit - the device I built was straight from the application note and I used a triac readily available in our poorly stocked parts stores. Any other suggestions for achieving the speed control by duty cycle control would be greatly appreciated.Trafo Quote Link to comment Share on other sites More sharing options...
ante Posted July 28, 2004 Report Share Posted July 28, 2004 Trafo,If you could remember a part of the name of the Siemens device maybe I could be found.Ante ::) Quote Link to comment Share on other sites More sharing options...
trafo Posted July 28, 2004 Author Report Share Posted July 28, 2004 Ante,I am 64 yrs old now and beginning to forget a lot, and I had that IC for a few years before I built the device with some help from a friend who found the application note for it - now he is gone and I suppose I will be too in the not too distant future! But one should keep trying. I have wanted to trace this IC or a similar one for a number of years, but it was only since last week that I have full time internet access that allows me to go to sites like this one to try to find things with help from good people like you.Trafo Quote Link to comment Share on other sites More sharing options...
ante Posted July 28, 2004 Report Share Posted July 28, 2004 Trafo,I Quote Link to comment Share on other sites More sharing options...
trafo Posted July 28, 2004 Author Report Share Posted July 28, 2004 I wish you were right. The building was torn down a few years ago and I have no idea if someone really smart decided to save my little circuit. I don't think there is any hope there. Which reminds me that I remember a childhood friend's house 1,200 KMs away from where I live that used to have a ceiling fan in the dining room that was an old - dating from the thirties - British two bladed fan that had a span of almost three metres and it turned so slowly that each time it went around one felt a whoosh of a breeze in a nice quiet way, and last year I saw that the building was in a bad way and learnt that it was going to be sold as my dead friend's remaining family were now living in town houses. A few hours later I began to wonder if the fan could be "rescued". Unfortunately, I did nothing about it, and it is probably gone now. "Sic transit gloria mundi".Trafo Quote Link to comment Share on other sites More sharing options...
ante Posted July 29, 2004 Report Share Posted July 29, 2004 Trafo,Well we have to come up with something NEW then. I Quote Link to comment Share on other sites More sharing options...
trafo Posted July 29, 2004 Author Report Share Posted July 29, 2004 Ante,I will be grateful, indeed, for a solution, old or new.Thank you,Trafo Quote Link to comment Share on other sites More sharing options...
GPG Posted July 30, 2004 Report Share Posted July 30, 2004 Cannot recollect the part No of the one you mention but this should dowww.atmel.com/dyn/resources/prod_documents/doc4768.pdf Quote Link to comment Share on other sites More sharing options...
trafo Posted July 30, 2004 Author Report Share Posted July 30, 2004 GPG,I have looked briefly at your suggested solution and will study it further to see if it will serve my purpose.Thank you,Trafo Quote Link to comment Share on other sites More sharing options...
MARTINMC999 Posted September 14, 2004 Report Share Posted September 14, 2004 the ic i think you are looking for is the SBL0587, Unfortunately discontinued, i need to find a replacement for it aswell Quote Link to comment Share on other sites More sharing options...
