Jump to content
Electronics-Lab.com Community
Posted
i am designing a closed loop capacitive accelrometer in Simulink, in which iam planning to use a pulse width modulator in the feedback loop. as my whole circuit in simulink is a mathematical approximation of the physical model.... iam kind of confused how to use the PWM block given in the SImulink library directly( since it is a time domain block, if iam correct!!) so i was planning to impliment the PWm block by using its Transfer function, so that the whole circuit would be in one form. but to my ignorance... i dont know how to write a transfer function for a PWM block. So can you please help me out with this.
Thank you in advance
Vishu
Posted
I think u can not write a transfer function for a PWM block. But u can create one easily. Create a counter which runs perpetually. (In the diagram i have not limited it's output but it is essential or u will get very large pulse width ;) )Then compare it's output with incoming signal thats all!
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
