Jump to content
Electronics-Lab.com Community
Guitar Amplifier
Hi :-)
I want to build a guitar amplifier, but i haven't found any useful schematics yet... I want it to be powerful, maybe 100 Watt if its possible, it has to be a clean pre-amp (which means: no distortion), low-noise as possible (no hiss) and a 3-band graphic equalizer (low, mid and high-controls), look at my drawing.
I'm a newbie in audio electronics, so i don't know that much about op-amps, transistors... you name it :-)
If you think you know much about it to help me creating some schematics, you are very welcome to post in this forum or to my mail-adress: peter(@)gawis.dk
Link to comment
Share on other sites
Ante, I've already tried building the pre-amp - the problem is, that the sound isn't clean. I wanted a clean pre-amp :-) But maybe i could use the power-amp schematic... Thanks :-)
Really nice site, EDY, but it's still tube-amps :-[ hehe
But, thanks for helping. I would really like some beginner-guides to build pre-amps with op-amps and/or transistors. Somebody in this forum must know something about that :-)
Link to comment
Sorry about the links to tube amps. :-[ I just did got these links from a google search and didn't read all the content.
You may be able to find a good amp on eBay. Sometimes it's cheaper to buy than build. I certainly got a good deal on my oscilloscope. Not that I could build an oscilloscope. ;)
Hope you're not building one of those giant wall amps from "Back to the Future". Your neighbors might get upset.
Cheers.
Darrin
Link to comment
I did build the pre-amp of this project:
100W Guitar Amplifier Mk II
http://sound.westhost.com/project27.htm
The problem was that almost nothing was comming out of the speaker unless i was turning up the gain-control, and then I got distortion. The Volume-control was as high as possible... then i looked on the project-site again, and changed some resistors but it didn't work very well....
I think its best if I start with a simple schematic... i think the dual opamp TL072 should be fine, but I don't know much about op-amps... so I need some help :-)
I explain: I don't need big complicated schematics of already build guitar-amps, I more need some beginner-info about building pre-amps with op-amps (or maybe transistors)
Thanks for helping me :-) - But I need more help :-( , so everybody is welcome to post some info :-)
Link to comment
I've builded this simple preamp with my friend for his guitar. It is more less just a simple active-out for guitar 'couse it is connected directly to magnet pickup. It worked like a charm. No distortion and clean sound. Best thing is it is as simple as it gets. I posted pictures below but try this link also for a little different wersion of the same pre-amp
http://www.till.com/articles/GuitarPreamp/index.html
Cheers
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
