mrtrhs Posted August 4, 2004 Report Share Posted August 4, 2004 ???i want to construct a pc osciloscope.anyone can help me? Quote Link to comment Share on other sites More sharing options...
ante Posted August 4, 2004 Report Share Posted August 4, 2004 Mrtrhs,What have you got so far?Ante ::) Quote Link to comment Share on other sites More sharing options...
vainajala Posted August 4, 2004 Report Share Posted August 4, 2004 I once tried this freeware program, and it actually worked quite well with soundcard input...http://www.saunalahti.fi/elepal/scope3.zip Quote Link to comment Share on other sites More sharing options...
surajbarkale Posted August 5, 2004 Report Share Posted August 5, 2004 You have to build an attenuator for scaling the input signal. Even then your bandwidth wil be limited to about 20KHz (i.e. AF range). If that is not sufficient, then you have to use a fast ADC with FIFO to store the samples then use Serial/Parallel/USB port to upload data to PC & write a program to analyze & display it! Also u may need a frequency synthesizer to generate various sampling rates such that you can measure a signal without overflowing buffer. you can also take a look at http://www.bitscope.com and analyze their design Quote Link to comment Share on other sites More sharing options...
