Jump to content
Electronics-Lab.com Community
Posted
Can any one help ???
2 switches S1 and S2 are used to control the operation of 2 pumps, p1 and p2. Were logic 0 signifies off and logic 1 on on both switches and pumps.
i) when S1 is operated p1 is turned on and p2 isturned off
ii)when s2 is operated p2 is turned on and p1 is turned off
iii)when both switches are operated simultaneously both pumps are turned off.
assume both switches can't change simultaneously
PART 1
Asynchronous Design
a) sketch a flow diagram for the above system
b)design an asynchronous circuit to implement the system
PART2
Synchronous Design
a)using your state assignment table of part 1b design a J-k flip flop solution for the problem
b) Comment on the validity of the above (2a) and how it will differ from a full synchronous design
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
