Guest Yevgenip Posted August 20, 2004 Report Share Posted August 20, 2004 I have an ITT Microphone whose wire connection is round and has seven pins in it.Does any one have a discription of the pin's function?I need to convert this connection to MIDI or PL2 (I think thats the regular earphone connection)thanks. Quote Link to comment Share on other sites More sharing options...
ante Posted August 20, 2004 Report Share Posted August 20, 2004 You could try Quote Link to comment Share on other sites More sharing options...
audioguru Posted August 20, 2004 Report Share Posted August 20, 2004 Hi Yev,Seven pins is a lot for a microphone that needs only 2 or 3.Maybe it is a stereo mic, so it has 2 mics in 1 housing.Does it have a press-to-talk switch? An ohm-meter would tell you which pins are the switch contacts.Maybe it has a built-in camera, recorder and/or alcohol (or bad breath?) detector. ;D Who knows?You also need to know its output level, depending on whether it is dynamic, electret or crystal. Electret and condenser types need to be powered, the others don't and shouldn't be. Quote Link to comment Share on other sites More sharing options...
