Jump to content
Electronics-Lab.com Community
Lambda/EMI TCR80S13
Sentinel
Sorry for the duplication also posted under datasheet help as well, just really stuck on this one:
Hello folks hope someone may be able to help me out. I've inherited some older power supplies which have me baffled(no manualto boot). The supply is a EMI(now lambda) TCR80S13-1-0V DC supply 0-80V 0-13A, it's SCR regulated, I only want to use it as locally variable. The problem is I can't get the crazy thing the put out any volts on the output.
It has 2 main posts and a 14 position terminal block with the following
1 + V
2+V Remote Sense
3 V Programming I
4 V Amp In
5 V Programming R
6 V programming R Com
7 -V Sense Remote
8 -V
9 I Programming I
10 I Amp In
11 I Programming R
12 - Shunt
13 Inverter Amp In
14 +Shunt
Tried several jumpered configs on the strip but no luck, if anyone knows what I'm doing wrong help would be greatly appreciated
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
