Jump to content
Electronics-Lab.com Community
Designing a computer based voltmeter
I would like to monitor multiple voltage signals at the same time through the parallel, serial or usb port.
The signals can be monitored on a rotating basis based on the speed of switching from one line to the other, however; I am not familiar with how to read the voltage.
For example, I want to monitor the voltage fluctuations on a circuit board, anywhere from 0 - 12 V DC. How could I do that?
From the programming (software) side, I have a reasonable idea on how to monitor the port, but from a hardware side, I do not.
I appreciate any help you can provide.
Thank you.
Link to comment
Share on other sites
You need an ADC & a microcontroller if you want to put data through USB or serial port. However for parallel port you can get away by using ADC & some logic chips. The selection of ADC will depend upon the resolution you want you can use any 10bit or 12bit ADC with integrated mux for the inputs. You will also need an attenueator at the input to protect ADC.
This is very similar to a Data Acquizition System take a look at http://www.geocities.com/hagtronics/pic_das/
Link to comment
Thank you both for the information. I read the information on the ADC but I do not fully understand the process.
Programming the picmicro seems easy enough, but wiring it, knowing what resistance to use, etc., I have not completed figured out.
Can you suggest a location to learn more information or possibly a site with a similar project.
Thank you.
Link to comment
Thank you.
The K8048 also looks interesting w/ a max input of 20V/40mA on the digital input side.
But, that begs the question - what is the difference between an analog signal and a digital signal when it comes to measuring voltage?
Being the "newbie" I have no clue, however; I would guess analog since the voltage fluctuates, rather than being "on" and "off." And, in the instance of measuring voltage, I want to know more than just "on" or "off."
Taking that into account, the K8055 only has 2 analog inputs, and the K8048 has 4, both with a potential maximum of 5V.
Again, I am not quite sure even where to start with this project, but I would like to try.
The parameters are to measure voltage from multiple inputs at the same time (or switching between them on the millisecond level is fine) and record the values through a computer program.
Obviously I can take a voltmeter and measure and watch the voltages but only one at a time, and I cannot record the information in a graph format.
So, I suppose you could say I want to build multiple voltmeters which take the information and save it on the computer.
Thoughts on how to tackle this project and/or where to start?
Link to comment
Just thought I would post some ideas for you:
Depending upon the range of input voltage, you could use a voltage divider to scale the voltage down to 0-5. This would limit the range you would be able to measure due to resolution limitations and you would want to use precision resistors with a very tight tolerance.
Another method is to use a voltage to frequency converter chip. Then read the frequency with the pin of a micro or with the PC port.
A third option is to use a voltmeter chip such as the one in our projects section and to read the lines that go to the LEDs as a binary word on the parallel port or a micro.
Hope it is helpful.
MP
Link to comment
Suraj,
Are you familiar with the project in the link you posted. I saw this earlier when I was looking for AVR based voltmeters, but I do not see how this unit accepts an analog voltage. There is also no source code posted so I was not able to check that. I was hoping you might know something about it.
MP
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
