Shahriar Posted September 30, 2004 Report Share Posted September 30, 2004 HiI have build a headphone buffer amplifier but there is a problem.at first the sound is weak then as the NE5532 becomes hot the sound increases untile the IC becomes very hot and then Hiss in sound appeares i have also made some changes, i have used a 100K Pot instead a !00K pot for every IC so that I can control the volume of all just by one Pot...the schemtic is attached...your help is appreciated in advance...Headphone_Buffer_Amp.pdf Quote Link to comment Share on other sites More sharing options...
Shahriar Posted September 30, 2004 Author Report Share Posted September 30, 2004 Hi oooooooooooohI Myself found the answer and this is the greatest exprience in my lifeI had forgotton to solder one of the jumpers whic was related to -Vee Net,so we take this result that if you forget to solder -Vee then the NE5532 gets hot and the device do NOT work properly ;D so remember to count the jumpers when you finished soldering, but I expected Distortion in case the Lack of -Vee but why the things i said above happened?Anyway I am very happy Quote Link to comment Share on other sites More sharing options...
