Jump to content
Electronics-Lab.com Community
Hi Shiva,
A digital filter can do a lot more than just separate signals into only 3 bands.
Texas Instruments took a cheap lousy-sounding speaker, and used a Digital Signal Processor IC to equalize it at many frequencies so that it sounded great! And the EQ can easily be changed with programming, at the touch of a memory button.
Modern stereos and car radios use digital filters. My factory car radio has "loudness" that is 'way too strong and a lousy sounding compressor that causes all the music in a song to change volume with each bass beat, but only on FM radio, the CD player in it doesn't compress. I can't turn them off, the radio is programmed that way.
I was in the middle of complaining in an e-mail to the radio station about their lousy-sounding compressor, when I heard the same song on my home stereo and it wasn't compressed. I quickly cancelled my e-mail.
Link to post
Share on other sites
Hi Shiva,
You don't understand that all the sounds are added togerther, then sampled. So the single sampling frequency is digitally modulated (digitized) with all the sounds. A processor can separate anything from the digitized information.
A similar thing happens with a simple loudspeaker. It can reproduce a lot more than just a single tone at a time, it can reproduce an entire orchestra: all the notes, all the instuments and all their harmonics. All at the same time because they are all added together to make the single output from an amplifier.
How about a DVD player? From a single sampling frequency its modulation has in digital form: 3 high-resolution colours, all the millions of locations on a screen, 5.1 channels of very high quality audio, error correction and even has extra information to show text on the player's screen. Since they are all added together, the player's processor must separate all the information and feed it to the proper outputs. Simply separating some audio frequencies would be easy.
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
