kumar_prashu Posted October 11, 2004 Report Posted October 11, 2004 HelloI need a sensor to locate the Exact position of the slot used in die casting machines. yes! for robotic application, Of Course.which type of sensor would be suitable for this type of operation, capacitive or any other. The same application requires to place the workpiece at a pre determined position in the slot. can anyone help!thanks in advance. Quote
surajbarkale Posted October 13, 2004 Report Posted October 13, 2004 Please be more clear. Post a sketch if you can. Quote
hotwaterwizard Posted October 14, 2004 Report Posted October 14, 2004 If the slot is open on both sides you can use an led and a Photo Transistor. When the light shines thru the slot it will trigger the circuit. Quote
