Jump to content
Electronics-Lab.com Community
urgent (counter question)
eie
Hi all.
well Kevin it is not exactly like that.
Normally you build counters using flip flops. According to how you will connect the clocks of your flip flops, you can get a sync. or an async. counter. You have a syncronous counter when all clock inputs of the flip flops are connected to a single, common clock. An asynchronous counter uses each flip flop's clock differently. You may want to take a look at this page for more details and some examples:
http://www2.ele.ufes.br/~ailson/digital2/cld/chapter7/chapter07.doc5.html
As for advantages and disadvantages, each counter fits in different applications and therefore I don't think you could make a comparison between them. In general you put sync. counters in synchronous systems and asynchronous in async. systems (these are the faster ones btw., but are more complex to design)
Link to comment
Share on other sites
  • 2 weeks later...
In a synchronus counter, all flip-flops have same clock signal. Thus the outputs of all flipflops change at same time. However a asynchronus counter dosen't has a single clock going to all ff's thus creating glitches in the output. Although asynch counter can be built with vrey little glue logic, it it not advisable at high frequency.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
