Jump to content
Electronics-Lab.com Community
AC current measurement
soundboy
Hi... I have a simple question, yet for some reason I'm blocked and can't figure out how to do this.
I have a system which generates a variable AC current . What I need to do is measure this AC current and somehow feed it back to a microcontroller (passing through a ADC first). In order to do this, I guess I need to take the AC current and obtain from it a proportional DC voltage level which I cand send back to the microcontroller.
Can anyone help me find the best way to achieve this?
Thank you!
Link to comment
Share on other sites
What you will find is that you already have a circuit. The AC is divided across whatever elements you have and the voltage divided by the resistance is the current. In the case of a single element, you don't have a voltage divider. But you still have the voltage and resistance and thus the current. What you are guessing at is the theoretcal situation in which you have a variable load with an AC source. Maybe a light activated resistor. But I think that even an ammeter uses the voltage over the known resistance to calculate the current.
Link to comment
I understand, but what I need to know is how to obtain a variable DC voltage level, which is proportional to the variable AC waveform I'm feeding into my system.
Hi Soundboy,
You described the function of a rectifier circuit.
It can be a simple, half-wave rectifier using only one diode but will have a 0.7V loss and won't rectify signals below 0.7V peak. It could also be a full-wave "absolute value" rectifier circuit using a couple of opamps, without any loss (can even have gain) and can rectify signals as low as millivolt levels.
Your choice.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
