Jump to content
Electronics-Lab.com Community
Pressure sensitive switch
My idea is to make a pressure sensetive switch, that can be used universally, kind of like the pressure sensetive buttons on a ps2 controller. Does anyone have any ideas? Maby a linear Pot with a strong spring under it, allowing less resistance the farther you push and thus the more pressure you put on it.
Link to comment
Share on other sites
Guest Yevgenip
It depends on what exactly you want to use it for.
The simplest way would be to make the switch change capacitance when pressed. You achieve this by putting a metal plate on the base of the switch and another on the moving part. when you press the switch, it will change capacitance (I don't remember: Increase/decrease).
Am I wrong?
If you want to use high pressures, try making it hydro.
Link to comment
Guest Yevgenip
I think my idea is better because you CAN make a FET pressure switch that is activated by the least resistance of your finger, but then you will not have much range of sesitivity.
If you still want the finger thing, I'll post a very basic schematic in a while.
Link to comment
Hi tweak232,
this circuit that I posted is still work in progress, D1 is not needed. You could use a hall affects sensor, but as you can see it requires a few components, and is probably a bit of an overkill for what you want. But it is very flexible, and you can make it work like the PS/2 controller, and the amount of pressure required to push the button in, is only limited to the spring required to return the button.%7Boption%7D
Link to comment
Guest Yevgenip
I got the formula for a capacitor made out of two metal plates seperated by an isolator:
C=E*A/d
When:
C = The capacitance in [Farads].
E = The material constant in [Farads/Meter].
A = The material area in [Meter^2].
d = The distance between the plates in [Meter].
About the circuit posted: Where does the switch go?
Link to comment
U1 is the hall affects sensor, which is placed beneath the button. Then you place a magnet within the underside of the button, the voltage rise and fall from pin 1 of U2, will correspond to the magnet travel towards an away from the hall affects sensor.
I hope this has been helpful :).
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
