timing circuit to run N-times
Guest Yevgenip
I think you need some sort of counter for that, that will count to the binary number you input. While counting, the motor will work, when it reaches the end - the motor will stop. The counter should be triggered by the voltage drop from the 555 timer.
Thanks Yevgeni.
Know of any good IC's for this purpose?
If I can't figure out how to use the counter, I can always just use multiples of my timing resistor.
If my timing resistor is R, then I can use 2R to run twice, 3R to run it three times, etc.
I know this isn't the most elegant solution, but then again, I'm no electronics guru.
Guest Yevgenip
Sorry, I can't recommend any good chips, I'm more of a theorist and I am not too keen about logic cheeps, only the logic behind them.
Yes, if you don't want to mess around with microcontrols, your solution is preety good.
Good Luck! ;)
