Guest Yevgenip Posted January 2, 2005 Report Share Posted January 2, 2005 Is there any way to make high voltage sparks that will not kill anyone? Quote Link to comment Share on other sites More sharing options...
ante Posted January 2, 2005 Report Share Posted January 2, 2005 Hi Yevgeni,It Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted January 2, 2005 Report Share Posted January 2, 2005 Yes, thats true, if you design a high voltage power supply with a high internal impedance then the output current will be too low to kill. For example if a 5KV supply has an internal impedance of 5M then the closed circuit current will be only 1mA Quote Link to comment Share on other sites More sharing options...
sec Posted January 2, 2005 Report Share Posted January 2, 2005 Alun has explained the theory pretty well, but on the practical side, you'll want to build something like a Van de Graaf generator, or a Tesla coil. Search around on the Internet; there are plenty of resources out there.A forum dedicated to these (and other) HV topics can be found at http://forum.4hv.org/index.php Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted January 3, 2005 Report Share Posted January 3, 2005 http://forum.4hv.org/index.php?board=10;action=display;threadid=2606 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted January 3, 2005 Report Share Posted January 3, 2005 ok back on topic,I don't consider Tesla coils a safe source of HV, Van de graff generators are.You can make also safe HV source by driving a fly-back transformer at 10KHz and conecting the output via a high voltage capacitor to limit the current. Quote Link to comment Share on other sites More sharing options...
Guest Yevgenip Posted January 5, 2005 Report Share Posted January 5, 2005 Anyone knows what dragon ball Z is? I thought about making two gloves that will fire sparks from one to another, but was scared I might kill some one. Quote Link to comment Share on other sites More sharing options...
steven Posted January 5, 2005 Report Share Posted January 5, 2005 :Dwelcome to the high voltage stuff section even 250 volts was conciderd high voltage still so if you want sparks or arcs that dont kill try the push button ignitor from a gas stove, whatever its voltage is im not sure Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted January 7, 2005 Report Share Posted January 7, 2005 Anyone knows what dragon ball Z is? I thought about making two gloves that will fire sparks from one to another, but was scared I might kill some one. As I said in my previous post, if you limited the current to a safe level you wouldn't cause any injury or death. Never the less I don't think you're glove idea is any good because the insulation on the gloves would have to be very thick to stop the electricity passing through the wearer. Quote Link to comment Share on other sites More sharing options...
danieleredivo Posted January 5, 2006 Report Share Posted January 5, 2006 Let's do some calculation: to make a spark between the two gloves, let's say they are 0.5 meters apart from each other, since dry air discharge break voltage is 3MV per meter, you need a 1.5MV = 1500 V (DC voltage) between your hands. I wouldn't play so close to it. Besides 5000 V seems to me extremely exagerated to obtain the spark.regards Quote Link to comment Share on other sites More sharing options...
audioguru Posted January 5, 2006 Report Share Posted January 5, 2006 Let's do some calculation: to make a spark between the two gloves, let's say they are 0.5 meters apart from each other, since dry air discharge break voltage is 3MV per meter, you need a 1.5MV = 1500 V (DC voltage) between your hands. I wouldn't play so close to it. Besides 5000 V seems to me extremely exagerated to obtain the spark.regardsHalf of 3 million volts is 1.5 million volts, isn't it?It isn't exaggerated. There is a link on another post to a 1 million volts DC thingy that produces arcs Four Feet Long! It uses four TV flyback transformers in parallel to power its voltage multipliers. I don't think anyone wants to be anywhere near it. Quote Link to comment Share on other sites More sharing options...
danieleredivo Posted January 5, 2006 Report Share Posted January 5, 2006 ooops, sorry I've mistaken then units. I correct my last post: for 0.5 m spark you need 1.5MV = 1500 kV = 1500000 V, so with 5000 V you can get a spark of almost 2 mm. regards Quote Link to comment Share on other sites More sharing options...
audioguru Posted January 5, 2006 Report Share Posted January 5, 2006 so with 5000 V you can get a spark of almost 2 mm.A piezo lighter. Quote Link to comment Share on other sites More sharing options...
