Jump to content
Electronics-Lab.com Community
Posted
HI guys, I've a receiver FTA Accessbox by metronic, It's = at another receivers with sti 5518. this is the data of receiver with winupoad 4.0 by null modem cable rs232:
DebugPort initialised to 115200, 8, N, 1
Failed to sense hot keys for the second time ... O[0] N[0]
No download demanded
Verify CRC => Part #01. START [7FF70000] Size[505644] CRC[D15812AB] Ver[ 13 ]
Terminating system services..
UnCompressed Image Size => [ 0x7FF50008 ] Bytes
Decompress Start => [ 0xC0783000 ]
Image Decompressed successfully...
Image StartAddress => [ 0x7FF70000 ]
UnCompressed Image Size => [ 0x7FF70008 ] Bytes
Decompress Start => [ 0xC0080000 ]
Preparing to start application..
BOOT ADDRESS => [ 0xC0192FBE ]
STAVMEM_Init()=Ok
STAVMEM_CreatePartition()=Ok
STEVT_Init()=Ok
STPWM_Init()=Ok
STI2C_Init(back)=Ok
STI2C_Init(front)=Ok
PTI interrupt level 6
src\pti\ptiinit.c 405> Suceesfully enabled the PTI interrupt
PTI_Init()=Ok
STCLKRV_Init(CLKRV2)=Ok
STCLKRV_Open(CLKRV2)=Ok
STAUD_Init(AUD0)=Ok
STDENC_Init(DENC0, InvOut 1)=Ok
STVTG_Init(VTG0)=Ok
STVID_Init(VID0)=Ok
STE2P_Init(EEPROM) Size[2048]=Ok
initterm.c, 1552 Info> Report module is initialised ...
flashdrv.c 1908> Flash Driver Init OK
main.c 352> Lnb [8] Sat [28] Car [40] Ser [32]memdata.c 307> Eeprom End Offset [512]
memdata.c 332> eDBE Box Info Size [28]
memdata.c 363> User Box Info Size [52]
memdata.c 394> Wakeup timer Info Size [224]
***************************** MPEG - ModuleInfo *****************************
      Platform Id   - STi5518
      Toolset Used   - DCU 1.8.1
      Compiled On    - Jan 28 2003 at 15:21:24
      MPEG Module Version   - Ver 1.3.14 Rev.0
VIDEO Matrix initialisation
stv6400.c 799> successfully created video matrix process
HWC_AVMATRIX_InitModule()= OK
vpwmctrl.c 215> Install PWM interrupt 11 at level 1
Res Start Address = C0783000
Res Data - 544F4F52 4F4C425F 00004B43 C0081238
   ||    eGOS Version 2.2.33.0         ||
   || PLATFORMID 551x Date Apr 21 2003 Time 11:55:17   ||
main.c 1118> Success in creating Common User interface
main.c 573> RF => CH No. [35], O/P Mode [1]
Summary of SDB:-
   Name BlkStart PLStart #Records
    Lnb C07EAE70 C07EAE80 7
    Satelli C07EAED4 C07EAEE4 10
    Carrier C07EAFFC C07EB00C 136
    Service C07EC32C C07EC33C 406
_-_-_-_-_ eIRRXVer3.1.0.0 May 31 2003 14:57:20 _-_-_-_-_
mmi.c 260> Success in creating IR Receiver Thread
fpkeys.c 424> FPKeyBoard Thread created @[6] with StkSize[3072]
########      AFTER MMI CREATE()
Major[2] Minor[2] Build[33] Platform[551x]Toolset[DCU Version] Date[n] Name[3]
Version of May 31 2003 at 14:49:20
Built for Chip STi5518 in board CPU Clock Speed = 81000000
System initialised - hit return to enter testtool
Heap Remaining : Start[C03D53EC] End[C03FDBEC] Size[162 Kb]
Heap Remaining In SYSTEM PARTITION: Start[C01D011C] End[C030591C] Size[1267712]
main.c 754> Lnb [8] Sat [28] Car [40] Ser [32]
= eDEMOD1.0-STV0299 Build R1.1.9May 31 2003 14:58:43 =
hwc0299.c 4125> TUNER (STV0299) Module Initialisation
Creating TUNER module semaphores ...
LNB Power Control by CPU PIO[2000C000] [20]...
LNB Polarisation Control by CPU PIO[2000C000] [40]...
Selecting Tuner ... Type[0D] Addr[C0]
nsfilter.c 3400> SECTION FILTER Driver version[HWC_SFILTER_55xx/3.0 May 31 2003 14:59:31.]
nsfilter.c 3419> Successfully intialised the Circular buffer Manager ...
nsfilter.c 3552> Creating SFILTER MONITOR Process @[9] WS[9216]
NO_OF_SIMULTANEOUS_FILTERS => 32
FILTER_DEPTH_SIZE => 14
MAXIMUM_NO_OF_STREAMS => 32
nsfilter.c 3633> Succesfully Installed SFILTER module
NDB Ver 1.7.4 built on May 31 2003 15:00:42
NAVDVB       Ver 1.2.6
BUILDER    Ver 1.2.9
STORAGE    Ver 1.2.2
MEMORY       Ver 1.2.2
DEBUG       Ver 1.0.3
ndbfcm.c 4366> Database successfully initialised
irdmon.c 449> Creating IRD @(5) WS[3072]
irdmon.c 499> IRDMON successfully created
navdvbif.c 379> Initialising Teletext...
         eTTXT - 4.4.0T3
          27/05/2003
Started Initialising...
Successfully Initialized Teletext Driver.
navdvbif.c 385> Opening VBIAppl ...
navdvbif.c 441> Initialised Audio WatchDog module ...
watchdog.c 697> Created the WD_Thread @12 Stk[4096]
navdvbif.c 457> Initialised HW watchdog module ...
dvbmmi.c 635> Successfully created TIMER_Thread
is there a compatible path for this receiver?
thank you!! PLEASE UPLOAD!!
  • 2 weeks later...
  • 7 months later...
  • 5 weeks later...
Posted
I have found this and think that it is the only way to patch metronic accessbox, I'm not able to use this but any people knows how to programmer.
ON WIDOWS XP:
GET TO START>ALLPROGRAMS>ACCESSORIES>COMUNICATIONS>HYPER TERMINAL
-INSERT A NAME AND SELECT AN ICON AND COM1 > PRESS OK
-SET BIT TO 115200
-PARITY=NEVER
-HARDWARE CONTROL=NEVER > PRESS OK
CONNECT METRONIC ACCESSBOX TO COM1 WITH NULL MODEM CABLE AND TURN ON(STANDBY=RED LED)
WAIT ANY SECONDS YOU CAN SEE ANY STRINGS ON HYPERTERMINAL
WHEN THE STRINGS ARE FINISHED PRESS ENTER.YOU ENTER IN TESTTOOL MODE.
WRITE HELP TO SEE ALL COMMANDS:
Testtool> HELP
  • 4 months later...
Posted
Voy a dar muchos datos por si alguien nos puede ayudar:
Procesador OMEGA ST i5518 BVC
flash 29lv800ta
Sintonizador SHARP F7VZ0184 chip STV 022998 (STV 0299)
Otros chip´s :
STV6400
IS42 S 164000-7T
Software: Suresoft Systems PVTS
Fabricante Software: Highgate
Decos iguales al Access:
Pacific DSR 2882
Infosat DSR 9100
Decos compatibles (aparentemente)
Zodiac DZR-760 CI; DZR 8310 ( fichero .urt)
Televes, 7296 ( fichero .bin)
Asahi, 20100
@sat, CI6100
Baff, DYB 3500 FTA ( fichero .urt)
Boca DSR 204 , DSL 212 ,.. 214, .. 216, .. 218
Comag FTA 35,.. 45, ..309,.. 310, DGI 500 OTA,
Silvercrest SL 65 (muy parecido los componentes) ( fichero .urt)
Interstar, DSR 9002
PACIFIC DSR 2800
Vestel, -> todos ( fichero .urt)
NeotionBOX NB 501,..601
Dyna, Cs 5500
Si alguien dispone de alguno de estos florecido que nos lo haga saber
Espero ayudar en la busqueda
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
