square to sine convertor
rohandayal
Hi Ro,
Welcome to our forum.
To convert a square wave to a sine wave, just filter its harmonics with a low-pass-filter. It must have a steep slope to pass the fundamental but attenuate the 3rd harmonic and above. 50-50 square waves don't have even-numbered harmonics. Use at least a 4-pole Butterworth LPF.
The web is full of and I have made converters using a switched-capacitor LPF IC. My extremely low distortion sine-wave generator uses a square-wave with over-sampling and a switched-cap LPF IC. The amplitude of its sine-wave is rock solid.
Hi Ro,
A PLL has a square-wave output so you would lose any amplitude changes of a sine-wave it is locked in frequency with. A PLL is useful to recover a sine-wave that is buried in noise or has frequency jitter.
A PLL output might have frequency overshoot and decaying frequency hunting with quick frequency changes of the sine-wave, or follow the frequency changes too slowly.
Then you just filter-out the PLL's square-wave's harmonics with a low-pass-filter like previously to end up with a pure sine-wave. ;D
If you could modify the square wave beforehand you would be better off. It requires that you use logic to insert a DC level of zero volts for a time at the zero crossing. There is a reason for converting a square wave to a sine wave and the applications are limited. It would seem very appropriate to construct a sine wave from an oscillator. I would like someone to tell me how it is done. I mean how do they actually get the value of the sine wave right. As I understand it, the output of an oscillator is basically a single rate of change. Sort of like a triangle. How do they accomplish the effect that gives rise to the rounding at the peak.
What frequency?
Try this circuit the formula for the frequency is 1.38/(RC) Just make sure the capacitors and resistors drawn in pink and labeled R and C are the same value.
The 555 generates a square and sort of triangle wave the first op-amp amplifies this, the R and C on the output low pass filters the triangle wave to give a sine wave, and the last amplifies this again. There are simpler ways to do this but I desined this circuit a long time ago, I used a dual sterio pot for R and a gang rotary switch to switch the value of C. I recomend you use 10
Thanks Guys,
When I first saw that new appl note, I built a buffered phase-shift osc and fixed its problems with a 4th opamp. I used 3/4th of a 4-gang pot I got out of a toy. It works great. Using a little low-droppout regulator, its amplitude is rock-solid and its distortion is very low. ;D
Hi Prateek,
A single integrator won't convert a square-wave to a sine-wave. Many integrator stages will attenuate the fundamental frequency as well as its harmonics. That's why I recommended using a multi-pole Butterworth low-pass-filter, because of its sharp cutoff.
Opamps don't have feeble amplification. They have an open-loop gain of hundreds of thousands and with negative feedback have almost any amplification you need.
