Jump to content
Electronics-Lab.com Community
Posted
HI EVERYBODY!
I OPENED UP THE CPU BOX OF MY COMPUTER FOR THE SECOND TIME
I COULD RECOGNIZE THE CPU CHIP ON THE MOTHERBOARD,A THICK BOOK TYPE HARDDISK!,AND A FEW OTHER BUSES.CAN ANYONE HELP ME IN KNOWING WHAT TYPES OF BUSES ARE THESE.THOUGH I KNOW A FEW WORDS LIKE ISA BUS,PCI BUS ETC.WHAT DO THESE BUSES ACTUALLY DO AND WHAT ARE THE DIFFERENCES B/W THESE BUSES.DO WE HAVE ANY OTHER BUS IN THE SYSTEM?
PRATEEK
Posted
The information you require can be found in
Tom's Guides here: http://www.tomshardware.com/
Or at :
http://www.anandtech.com/
If you know the name and # of your motherboard you can find descriptions and pictures on the manufacturers homepage.
  • 2 weeks later...
Posted
The difference b/w an ISA slot and a PCI slot is that ISA slots are 16 bit and PCI slots are 32 bit. ISA slots are used in old computers thay are long usually black coloured but you should know that ISA slots are no longer manufactured.For more info try to search in google or sth.
Posted
I should warn against using color of the connector to determine the type of buss. I have seen and purchased these connectors in different colors in the past. There are other obvious differences in the buss connection. You cannot insert a card into the wrong buss. You should look at the characteristics of the connector to see the differences.
MP
Posted
ISA is no longer commonly available in nowadays motherboard.... except some industrial mini size controller board
and do not "visually" distinguish the bus .......... get yourself a manual of the motherboard..... it will clearly state what are these!
Posted
Look at these links they might be useful ! ;D ;D ;D
http://www.quatech.com/support/comm-over-isa.php
http://www.quatech.com/support/comm-over-mca.php
http://www.quatech.com/support/comm-over-pci.php
http://www.quatech.com/support/comm-over-cpci.php
http://www.quatech.com/support/comm-over-pcmcia.php
http://www.quatech.com/support/comm-over-usb.php
Posted
hi everybody!
actually i wish 2 know the reason behind using so many buses in a computer .why not a single bus for all types of communication.like for example,
why to connect printer and digital camera on different buses or ports?
plz reply soon
prateek
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
