Shahriar Posted March 24, 2005 Report Share Posted March 24, 2005 HiI want to build a Parallel Hardware lock which can connects between Printer and PC Port.I would appreciate it if I could use a serial EEPROM to Store some data.Any schematic or Idea is appreciated in advance.ThanX - Shahriar Quote Link to comment Share on other sites More sharing options...
prateeksikka Posted March 28, 2005 Report Share Posted March 28, 2005 HI SHAHRIAR! U HAVE DO BE PROFICIENT IN ONE OF THE PROGRAMMING LANGUAGES PREFERABLY 'C' FOR DEVELOPING THE LOCK!YOU CAN STORE THE CODE IN AN EEPROM OR ANY MEMORY STICK(ON A USB)AND INPORT THE CODE!FROM THE PORT ADDRESS(YOUR PROGRAMMING SKILL IS TESTED HERE) BE CAREFUL WHILE USING THE INPORT COMMAND.BE SURE WITH THE ADDRESSES AS THE PORTS ARE CONNECTRD TO MOTHERBOARD DIRECTLY.IF THIS CODE MATCHES EXIT THE LOOP WHICH CHECKS FOR THE CODE AND GIVE THE PRINTER COMMANDPRATEEK Quote Link to comment Share on other sites More sharing options...
