Jump to content
Electronics-Lab.com Community
Stupid atx question
AJB2K3
It sounds like you are describing the 4 pin molex connector.
The two black wires in the middle are ground, and you should read voltages with your negative lead connected to them.
The negative voltages supplied by your power supply are -5 and -12V, and they will connect to your motherboard only.
All the grounds are connected together, and the negative and positive voltages are referenced from them.
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
