BeoLOVE Posted April 26, 2005 Report Share Posted April 26, 2005 Hi to everyone...I'm new member and i want to help me to make my idea in reality.In my highschoole for electronics i get an idea for ideal AC-DC coverter without transformer.I made the circuit for small voltage (1-2 Vpp~) and as i expected it worked. In output there wasn't a broom voltage (the ~ components in output that is in range of microV) My profesor was also suprised about that. But he never give me a elan to coontinue to develop this idea for high voltage.But now, after 4 years i'm student of Informatic science and i still love electronics and I realise that is so usefull idea for companies to make products without stabilizators.Let me shortly explain my idea.- On inputs i use the standard voltage AC ~220V/50Hz- transforming this voltage to ideal DC -- 220VI have one Q, so i can realize this idea.So, please help me.It is good idea to first to transform the input voltage then to converting to DC or DC 220V with Trimer/Potenciometer to regulate the voltage?All the best and thanks for your help,Elvis Hajdar Quote Link to comment Share on other sites More sharing options...
ante Posted May 13, 2005 Report Share Posted May 13, 2005 Hi Elvis,Welcome to this forum.I am not sure I can help you but if you could post the circuit someone might be able to. Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted May 15, 2005 Report Share Posted May 15, 2005 This project is easier than you think.All you need is a switched mode power supply.The 220V AC is connected to a bridge rectifier, with filter capacitors, the voltage output will now be:220 * 1.414 = 311.26 - 1.4 = 309.72VDCTo convert the 309.72VDC to 220VDC you need a buck switch mode regulator, they're a lot of chips available to perform this function. Most of them will have a maximum input voltage of <60V but we can get round this by using a very small zener regulator, and external transistors to buffer the internal switch.Here are a few IC that might be of some use:http://www.onsemi.com/pub/Collateral/LM2574-D.PDFhttp://ww1.microchip.com/downloads/en/DeviceDoc/21365b.pdfhttp://www.ee.washington.edu/stores/DataSheets/voltreg/tl497.pdf Quote Link to comment Share on other sites More sharing options...
