CYSSOU Posted May 4, 2005 Report Share Posted May 4, 2005 Hi,I'm looking for electronics rules in 220V PCB design.If anybody have informations about copper thickness, isolation between tracks and all these stuffs, I 'll be pleased.Thanks. Quote Link to comment Share on other sites More sharing options...
ante Posted May 13, 2005 Report Share Posted May 13, 2005 Hi CYSSOU,The same rules as for any pcb will be ok. The copper thickness is not related to volts but to amps and the track spacing is dependent on the components you like to use. Quote Link to comment Share on other sites More sharing options...
MP Posted August 16, 2005 Report Share Posted August 16, 2005 If you do not conformal coat the traces, then there will be arcing in the future when dust accumulates on the board. Also, there are some design rules to be found on the web for high voltage track spacing. It is dependent upon several factors, but it is possible to get arcing between traces under the right circumstances.You should post your pcb question in the PC Board area since most members interested in making boards will be there.MP Quote Link to comment Share on other sites More sharing options...
ante Posted August 16, 2005 Report Share Posted August 16, 2005 A good rule (for any pcb) is never to leave it uncoated, and this goes for both sides. Even if there are no HV present, the solder and the copper will corrode and cause problems in the future. Dust and other contaminations will disturb the circuits function if it’s allowed to collect moist. This is very important for all pcbs no matter what voltage we are talking about. Quote Link to comment Share on other sites More sharing options...
MP Posted August 17, 2005 Report Share Posted August 17, 2005 I totally agree. Another related area is wires soldered to the board. Bare solder and/or bare wires are going to corrode, too. MP Quote Link to comment Share on other sites More sharing options...
