Guest Alun Posted May 28, 2005 Report Share Posted May 28, 2005 The mains side won't register because the resistance is too high,use the ohms setting to measure the resistance, you won't get a valid reading with the battery connected and it might damage the meter as well. Quote Link to comment Share on other sites More sharing options...
scuba14c Posted May 28, 2005 Author Report Share Posted May 28, 2005 the battery wasn't connected when I measured it. The charger is only giving me a 2-3 V charge when I use just the transformer. Any ideas?? Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted May 29, 2005 Report Share Posted May 29, 2005 What transformer did you use?Did you try altering the frequency?Which sisde did you connect to the circuit? - it should be the low voltage side.Did you try reversing the connections on either the low or high voltage side of the transformer? Quote Link to comment Share on other sites More sharing options...
scuba14c Posted May 31, 2005 Author Report Share Posted May 31, 2005 I don't think I've figured out how to build and/or use the driver yet. Will someone explain how to assemble it and operate it? Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted June 1, 2005 Report Share Posted June 1, 2005 What materials do you have access to?I would personally etch a PCB, but you can buy strip board or you could even solder it togeather with bits of wire if you want but I wouldn't recommend it. Quote Link to comment Share on other sites More sharing options...
scuba14c Posted June 1, 2005 Author Report Share Posted June 1, 2005 I have it soldered together with wires, but I can't get the switch to oscillate. I have tried it on the boost converter, the converter using the transformer and a flyback driver. Could you give me a diagram showing me how to connect the boost converter driving circuit (what wire goes to which pin, how I start operating it). How do I start the switch oscillating? Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted June 1, 2005 Report Share Posted June 1, 2005 Try using strip board.Why are you having trouble with pin numbers? The circuit you first posted had the pin numbers on. Quote Link to comment Share on other sites More sharing options...
scuba14c Posted June 2, 2005 Author Report Share Posted June 2, 2005 The pin numbers aren't the problem, I can build the 555, but the switch I'm using won't oscillate. It only boosts until 30V, with either the boost converter or transformer. I'm not sure if the equipment I'm using is wrong or if I don't know how to operate the circuit. Quote Link to comment Share on other sites More sharing options...
scuba14c Posted June 2, 2005 Author Report Share Posted June 2, 2005 Just realized what you were asking. I meant the pins on the IGBT or transistor. Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted June 2, 2005 Report Share Posted June 2, 2005 What's the part number?The answer's on the datasheet. Quote Link to comment Share on other sites More sharing options...
scuba14c Posted June 2, 2005 Author Report Share Posted June 2, 2005 I need to see if I am connecting the leads to the right pins. For some reason it will only oscillate to 30V. Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted June 2, 2005 Report Share Posted June 2, 2005 I need to know the part number on the transistor or else I can't help you. Quote Link to comment Share on other sites More sharing options...
scuba14c Posted June 3, 2005 Author Report Share Posted June 3, 2005 I've been using 3 different kinds:400V 8A NPN transistor TO-220 case http://www.alliedelec.com/cart/ProductDetail.asp?SKU=568-4088&SEARCH=MJE13007&ID=&DESC=MJE13007***This one is the only one that will get to 30V, the other two reach 20-25V***500V 14A Field Effect N channel power transistor TO-247AC case http://www.alliedelec.com/cart/ProductDetail.asp?SKU=273-9997&SEARCH=IRFP450&ID=&DESC=IRFP4501200V 20A IGBT TO-247 case http://www.alliedelec.com/cart/ProductDetail.asp?SKU=273-7740&SEARCH=IRG4PH50K&ID=&DESC=IRG4PH50K***The last two have to have the 555 timer going to charge and make a whining sound. For the first I touch it the back and right pin of the transistor once and it will go to 30V. If I try operating the 555 timer while it's charging, it stops. Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted June 3, 2005 Report Share Posted June 3, 2005 I've located the data sheets for you: MJE13007IRFP450 IRG4PH50KFirstly have you connect the connections to the right pins?The problem with the MJE12007 was base series resistor (R3) is too small, 10ohms is fine for a MOSFET or IGBT but not for a bjt as the base will act as a short to ground. I recommend you keep the 10ohm resistor and go with the MOSFET.You are currently only varing the frequency at the moment, try using this circuit to alter both the frequency and duty cycle:Also connect a big juicy 1000uF capacitor in paralel with the whole circuit. Quote Link to comment Share on other sites More sharing options...
scuba14c Posted June 3, 2005 Author Report Share Posted June 3, 2005 Part of the problem I am having is not being sure if I am connecting things to the switches the right way.I will try the circuit you provided and see if it works. Quote Link to comment Share on other sites More sharing options...
scuba14c Posted June 4, 2005 Author Report Share Posted June 4, 2005 Is there a way to change the 100k resistors to lower values? The most I have are 20k power resistors. I am connecting the 555 timer output (+) to the back of the transistor and the (-) to the left pin. The center pin is connected to the output side of the inductor. The right pin is connected to the negative terminal of the capacitor. To start it I give it a pulse with the timer and then touch the negative side of the battery to the right pin of the transistor. This will get me to ~28V in less than a second, but it takes 10 seconds longer for it to reach the 32V maximum.Is this the way it should be connected? Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted June 4, 2005 Report Share Posted June 4, 2005 Is there a way to change the 100k resistors to lower values? The most I have are 20k power resistors.You don't need power resistors, two low power 100K potentiometers (variable resistors) are what you need. I am connecting the 555 timer output (+) to the back of the transistor and the (-) to the left pin. The center pin is connected to the output side of the inductor. The right pin is connected to the negative terminal of the capacitor. To start it I give it a pulse with the timer and then touch the negative side of the battery to the right pin of the transistor. This will get me to ~28V in less than a second, but it takes 10 seconds longer for it to reach the 32V maximum.Is this the way it should be connected?Look at the picture below:Pin 1 to the output from the 555.Pin 2 to the transformer.pin 3 to 0V.Connect the other end of the transformer to +V.All the connections to the transformer I've talked about in this post involve the low voltage side of the transformer.I hope this helps. Quote Link to comment Share on other sites More sharing options...
scuba14c Posted June 5, 2005 Author Report Share Posted June 5, 2005 I tried it but it didn't work. Was the ground from the timer supposed to go to the back of the transistor? I have a circuit layout from someone else who built a boost converter, but am unsure of one of the components he used. The diagram for the boost converter does not show it. Could you identify the device on the upperleft hand side of the board? Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted June 5, 2005 Report Share Posted June 5, 2005 I tried it but it didn't work. Was the ground from the timer supposed to go to the back of the transistor? What do you mean the back of the transistor?Source, Gate, Drain?Do you mean the metal tab as it's connected to the drain as is pin 2.I have a circuit layout from someone else who built a boost converter, but am unsure of one of the components he used. The diagram for the boost converter does not show it. Could you identify the device on the upperleft hand side of the board?It could be a transistor or a voltage regulator but I can't tell without the part number.Did you use stripboard this time, because connecting the components together with wires isn't the most reliable construction technique. Quote Link to comment Share on other sites More sharing options...
scuba14c Posted June 6, 2005 Author Report Share Posted June 6, 2005 Yes, the one I meant was connected to pin 2. I bought a breadboard and used this for as many parts as possible. Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted June 6, 2005 Report Share Posted June 6, 2005 Beadboard isn't that good either as the contacts aren't always very reliable, stripboard your best bet and after that you can etch your own PCB if you want. Quote Link to comment Share on other sites More sharing options...
Anotherforummember Posted August 11, 2005 Report Share Posted August 11, 2005 All is good now. Scuba got my board, did a little toasting to it. Board fixed and now in service. Still in service Scuba? Quote Link to comment Share on other sites More sharing options...
scuba14c Posted August 18, 2005 Author Report Share Posted August 18, 2005 Yeah, it's fixed. Quote Link to comment Share on other sites More sharing options...
