Shahriar Posted June 12, 2005 Report Share Posted June 12, 2005 HiIn many crystal Tx oscillators, I always see that if the oscillator frequency is for example 98Mhz, the crystalvalue is sth around 12MHz.(a little bit more or less).I have heard sth. like second or third harmonic but do not know anything exact.My questions are:1- how to calculate the crystal value...2- when the oscillator has a common-base Amplifier the crystal is placed in base(or Gate if mosfet). WHY?ThanX in advanceShahriar Quote Link to comment Share on other sites More sharing options...
prateeksikka Posted June 13, 2005 Report Share Posted June 13, 2005 2- when the oscillator has a common-base Amplifier the crystal is placed in base(or Gate if mosfet). WHY?it is connected to base because we can exploit transistors high value of beta(B)to use it as a good amplifier only in this configuration.integral multiples and not same value is used to avoid frequency distortion which may push it away from resonance Quote Link to comment Share on other sites More sharing options...
Shahriar Posted June 13, 2005 Author Report Share Posted June 13, 2005 Dear prateeksikka Thank you very much for your answer butI found a Application note which contains answers. (I attached it)The reason is: "The practical frequency range for Fundamental modeAT-cut crystals is 600 kHz to 30 MHz. Crystals for fundamentalfrequencies higher than 30 to 40 MHz arevery thin and therefore fragile. Crystals are used athigher frequencies by operation at odd harmonics(overtones) of the fundamental frequency. Ninth overtonecrystals are used up to about 200 MHz, the practicalupper limit of crystal oscillators" {Copied from this PDF}ThanX againShahriar Quote Link to comment Share on other sites More sharing options...
prateeksikka Posted June 14, 2005 Report Share Posted June 14, 2005 but this does not explain that why do we need higher frequency or nth harmonics of the fundamental than what is required. ;D i.e your own question why dont we adopt a crystal of same value and why of a higher one? Quote Link to comment Share on other sites More sharing options...
Shahriar Posted June 14, 2005 Author Report Share Posted June 14, 2005 Sorry, I forgot to attach the PDF..Building Crystals for High frequencies is difficult and Expensive. For example if You want to build a 150Mhz Oscillator, you will never find such Crystal, you should use a 30MHz Crystal and design a 5th Overtone Oscillator.Everything is explained in PDF...ThanXShahriar00826a.pdf Quote Link to comment Share on other sites More sharing options...
