Guest Alun Posted August 11, 2005 Report Share Posted August 11, 2005 http://www.romanblack.com/a04.htmAdd an extra transistor and you can have currewnt limiting, in fact if you removed the zener and set RS to the right value for the forward cuurent you want, you'll have a switching constant current source which would be ideal for powering high intensity white LEDs. Quote Link to comment Share on other sites More sharing options...
ante Posted August 12, 2005 Report Share Posted August 12, 2005 Hi Alun,I found it! Maybe you can calculate the efficiency, since you are good with figures? 8) Quote Link to comment Share on other sites More sharing options...
audioguru Posted August 12, 2005 Report Share Posted August 12, 2005 Hi Ante,That's a cool charge-pump circuit. ;DThe current through the zeners is about 20mA continuously, and the transistors will drop out of saturation if the total load current exceeds about 200mA for each transistor if they are weak.Therefore the efficiency is about 95% before adding the 0.5V saturation loss of each transistor. ;D Quote Link to comment Share on other sites More sharing options...
ante Posted August 12, 2005 Report Share Posted August 12, 2005 Hi Audioguru,Thanks for the assessment, what’s the bottom line then? The darlingtons have more than 1000 in gain so there is no problem. The converter put out 2.5A for hours and stayed cool! 8) Quote Link to comment Share on other sites More sharing options...
audioguru Posted August 12, 2005 Report Share Posted August 12, 2005 Hi Ante,Sorry I didn't notice that your transistors are darlingtons. They don't look like darlingtons.In a half-wave charge pump the transistors must conduct twice the load current, right?For your 2.5A load, each darlington conducts 5A and its max saturation voltage is 2V. Therefore their max dissipation is 10W each for half the time which averages to 5W each continuously. Your darlingtons were probably better than minimum spec, and you were lucky. ;D Quote Link to comment Share on other sites More sharing options...
ante Posted August 12, 2005 Report Share Posted August 12, 2005 Hi Audioguru,Yes, I might have been lucky. Don’t you think the minimum specs are very rare? I think so because the manufacturers like to have a good margin to play with! Can you honestly say you have ever found any semiconductor with minimum spec? Well I haven’t not even close to minimum! Maybe back in the germanium days, when I built my first variable bench psu with an AD149 on the back! ;D ;D Quote Link to comment Share on other sites More sharing options...
audioguru Posted August 12, 2005 Report Share Posted August 12, 2005 Hi Ante,I always design circuits using manufacturers' guaranteed minimum specs and everything works fine. ;DI also still have my very first psu that has a BDY38 (I have its 1968 datasheet) silicon transistor replacing its original germanium AD149. I can hardly read the label on it since it is badly pitted from zapping shorted Ni-Cads. ;D Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted August 13, 2005 Report Share Posted August 13, 2005 Why not make it even better by using MOSFETs Quote Link to comment Share on other sites More sharing options...
ante Posted August 13, 2005 Report Share Posted August 13, 2005 Hi Audioguru,I agree, caution is a virtue (better safe than sorry)! And I am sorry to have confused you with the wrong transistor symbols. At the time when I converted the old doodle to this drawing I couldn’t find the correct symbol for a darlington. Unfortunately I have lost my old psu along the way, 35 years is a long time for any psu! I still got my number two psu though; it has a 2SD92 on the back 0-20V@1A! :oAlun,Yes why not, go ahead make it more up to date and efficient! Quote Link to comment Share on other sites More sharing options...
ABU SHEREEN Posted December 29, 2005 Report Share Posted December 29, 2005 THANKS Quote Link to comment Share on other sites More sharing options...
jasssam Posted April 11, 2006 Report Share Posted April 11, 2006 Good day every bodyI would like circuit Switching power supply which use IC LM2575http://www.elec-micro.com/electronics--project--Swictching%20regulator.htmlhttp://www.elec-micro.com/electronics--project--Swictching%20regulator.html Quote Link to comment Share on other sites More sharing options...
engrmAsif Posted February 4, 2007 Report Share Posted February 4, 2007 Hi i m new on the forum.but old for electronics.i think u should change the resistor with a high power resiter.its easy ................. Quote Link to comment Share on other sites More sharing options...
bridgewater Posted June 20, 2010 Report Share Posted June 20, 2010 =Underdog=HelloI'm new to this board and My name is Peter, I found this thread in the google search engine, while searching something and I found this community and sounds interesting.Hopefully I can contribute something to the community though.Wow nice,,, Thanks for sharing your knowledge Guys... God Bless Quote Link to comment Share on other sites More sharing options...
Guest nosak Posted August 9, 2014 Report Share Posted August 9, 2014 give us design ;D Quote Link to comment Share on other sites More sharing options...
