hi i have some solder and when i make a joint with it it never goes shiny so i got out a bit of flux and dipped my iron in it still no shiny joint i make a joint with my other solder shiny but i'm running out of that solder (time to order some) but any way i can't get that solder to make a good shiny joint i thought it might not have a flux core so i put the flux on like i said eayrler and nope so whats wrong
it came with a set with a cheap iron a soltering gun and some solder and a thing of flux i bought a new gun (not temp controlled need to get one of those ) the cheap iron was broken and the handle gets realy hot so that is why i got a new iron but i know it can't be getting to hot for the solder because i thing the irons were the same wattage
For good soldering:
-Hot iron (but not too hot to destroy pcb tracks or component 300-350c is good)
-solder with fluxed core. The other ones are headache...  The solder must be 60% of Sn and 40% Pb
-Practice, and more practice
I use 63/37 "electronic" solder which is the alloy percentages that goes instantly from liquid to solid as it cools, without the "plastic" mode that makes cold solder joints.
I call 60/40 solder, "plumber's solder". ;D ;D
but one more question what is wrong with 60/40 solder that is what i see most even in electrical shops i'd think as long ans it makes a good joint it would be ok for what i use
ps sorry i didn't read your post closly for pcb work it is generly ok as long as the parts don't move right? i think i've used 60/40 solder my whole life i'm not sure but i've used it alot and it seems fine to me
availability????
I can get just about anything in Canada, and I was talking to Cody who can also get just about anything in the US. I am sorry, Gsmaster, that you or others live in a country with limitations. :(
