Birdie Posted July 6, 2005 Report Share Posted July 6, 2005 helloi need that the question i'll ask is a very silly one but i really dunno it's answer.. I have an on/off switch with 6 pins & i have no idea how to connect it ..can anybody help me ? Quote Link to comment Share on other sites More sharing options...
Guest SM2GXN Posted July 6, 2005 Report Share Posted July 6, 2005 Hi Birdie!There is almost :) no silly questions and yours is'nt silly.If you got an DMM you can measure your switch quite easy.If there is two pin rows at the connector it is probably a two pole switch, if you measure from those in the middle they will get in contact to the outer pins, which side of the middle is dependent on the position of your switch.Do you have any photo or link to an similar switch?Bjorn Quote Link to comment Share on other sites More sharing options...
Birdie Posted July 7, 2005 Author Report Share Posted July 7, 2005 heythanks for ur help.. i don't have a picture to that switch & my camera has something wrong so i can't send a picture of ii but i can describe it.. it has 2 rows each of 3 pins. I duuno what to say more about.. Quote Link to comment Share on other sites More sharing options...
audioguru Posted July 7, 2005 Report Share Posted July 7, 2005 Hi Birdie,Your switch is probably a double-pole, double-throw one. Its center pin on each row connects to an end pin, then to the pin on the other end when it is switched. ;D Quote Link to comment Share on other sites More sharing options...
Guest SM2GXN Posted July 7, 2005 Report Share Posted July 7, 2005 Excellent audioguru :) it's always better with a picture. Quote Link to comment Share on other sites More sharing options...
Birdie Posted July 7, 2005 Author Report Share Posted July 7, 2005 thanks all for the help Quote Link to comment Share on other sites More sharing options...
Birdie Posted July 7, 2005 Author Report Share Posted July 7, 2005 BUT what about the other row ??? Quote Link to comment Share on other sites More sharing options...
audioguru Posted July 7, 2005 Report Share Posted July 7, 2005 The other row is completely electrically separate from the 1st row. Use it if you need something else switched. ;D Quote Link to comment Share on other sites More sharing options...
MP Posted July 8, 2005 Report Share Posted July 8, 2005 Birdie, in other words, it is like two of the switches in audioguru's post sitting side by side but only one lever controls both of them.MP Quote Link to comment Share on other sites More sharing options...
