walid Posted July 19, 2005 Report Share Posted July 19, 2005 if I have to amplify a sig of 10mV peak (20mV P-P) using a voltage divider common emitter configuration. Power supply is 9VDC. What values of RB1 & RB2 should be to maintain these two conditions:1- conserve (not waste) the battery.2- No distortion in the o/p sig.Note: please write the expression you use to solve this problem, thanks. Quote Link to comment Share on other sites More sharing options...
audioguru Posted July 20, 2005 Report Share Posted July 20, 2005 if I have to amplify a sig of 10mV peak (20mV P-P) using a voltage divider common emitter configuration. Power supply is 9VDC. What values of RB1 & RB2 should be to maintain these two conditions:1- conserve (not waste) the battery.You can design a transistor circuit to use any amount of battery current you want. It all depends on the resistance of its load.2- No distortion in the o/p sig.The amount of distortion of a single common emitter transistor depends on its load resistance and its gain.Since you don't specify a load resistance nor amount of gain required then a solution is impossible. :( Quote Link to comment Share on other sites More sharing options...
