Jump to content
Electronics-Lab.com Community
Audio Transformer
walid
i have many Audio Transformer from my scrap, there is no part no., no spcification or anything to identify it.
i want to use them in audio circuits, but i want to made some experiments to make an initial idea about them, i kow they are consista of a primary and secondary coils, the primary has three terminals and the secondary has two.
in sammery i want to know its impedance ratio.
thanks.
note dont tell me that put connect it with say 1v rms (50Hz) and measure the output, i know this i want some thing new.
you all very good.
walid.
Link to comment
Share on other sites
In general the lower the frequency the bigger the transformer you'll need for a particular power level but of course higher power ratings require larger transformers.
Link to comment
OK, given the fact that we are dealing with an audio transformer we can also assume that the frequency range is in the audio spectrum?  Would it then be false/true to state that “The physical size reveal to some degree the power rating.” ?
Link to comment
Yeah, a 50W 50Hz mains transformer is pretty big, a 20Hz 50W transformer will need to be over twice as big, but there again if a 100W transformer has a mimimum frequency of 100Hz couldn't you just use it at 20W with 20Hz?
Hang on it might not be that simple, to avoid saturation you'd have to reduce the input voltage by a factor of 5 so the power level would be a lot lower than 20W unless you reduce the output load impedance by the same factor.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
