Jump to content
Electronics-Lab.com Community
laser lights
ECET0purdue
hello,
ok i got an 24v power supply going to a POT. i then get 5V from the POT.
the POT is 2 watts 5k.  The laser lights are pulling 65MA and are 5V This will not work?  if i connect it to The pot it, the voltage drop is too much.. now the question is what kind of POT should i get? more or less watts or ohms, and whould it have any effect on the 24Vs comming in...(iam using the 24 volts for another divice) any help would be good thanks.
glen
Link to comment
Share on other sites
It will be better to use a voltage regulator instead of a pot. Especially when you are powering more than one device at different voltages. The resistance of the pot will become part of ohms law of your other branch of the circuit. Load will shift. In other words, you will never get a steady current as other loads on the circuit are attached or vary. Actually, a LM7805 probably costs less than a 2 watt 5K pot.
MP
Link to comment
  • 2 weeks later...
Hi
You may have already built that 5V supply but... I recently found some ready made very easy to use switching regulators made by Texas Instruments (Powertrends to be more specific). They do operate at 24V, have outputs of 5V, as you need, and adequate output currents. What is even better is that you can have free samples of them. Check out PT5100 (5V/1A) or PT4142 (5V/4A), You may look at TI's site under:
Analog and Mixed signal -> Power management -> Plug-in power modules
and find the regulator that suits you best.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
