Jump to content
Electronics-Lab.com Community
COILED RESDISTOR?
prateeksikka
The answer is you'd get both inductance and resistance and some capacitance too, the amount of each will depend on the dimensions of the coil, the metal the wire's made of and the frequency.
Link to comment
Share on other sites
One time at this place I worked, they had these waveguide filters that needed to be tuned. The part that you tuned appeared to be a capacitance screw that had a metal outside and a core on the inside. You put the screw into the waveguide and from there you could adjust the protruding capacitance core. Well on some types of these waveguides, the signal that was input to the waveguide through a coaxial type connector was shorted to the metal outside. It turned out that this apparent short was a filter. Just a small wire shorting the inside conductor to the metal outside. I later read in a book that sometimes a shorted piece of coaxial cable could be used as filter with a calculated Q,bandwidth, and resonant frequency.
Link to comment
In our schooldays when we were asked to measure the resistance of a piece of wire our teacher always told us to coil it up.
I dont understand even now why? What difference does it make?
If it was a very long piece of wire, if it was not coiled then you might be tempted to add long connecting wires to your ohm-meter to connect to the far ends of the wire being measured.
Then you would have quite an error. :(
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
