Jump to content
Electronics-Lab.com Community
relays - SPST, SPDT, DPST, DPDT?
PaulKraemer
Hi
From what I understand, a relay has a control circuit and a power circuit.  If you energize the control circuit, the power circuit is closed.  I have seen relays advertised as single-pole single-throw (SPST), single-pole double-throw (SPDT), double-pole single-throw (DPST), and double-pole double-throw (DPDT).  I am not familiar with these terms.  I was wondering if anyone could give me an explanation, or point me towards something I can read to learn more.
Paul
Link to comment
Share on other sites
Well the power circuit is just a switch, the control circuit is just what moves the lever.
Now think of a simple On-Off switch with two connectors. It's a simple throw (one On position) simple pole switch (SPST). Two such switches operated by the same lever would be DPST.
If it was On-Off-On it would be SPDT and DPDT respectively.
HTH, Nikolas
Link to comment
Hi Paul
SPST - Single Pole Single Throw - Otherwise known as an on-off switch.
SPDT -Single Pole Double Throw - Single pole changeover switch, ie, with no power to relay, centre connects to one side. When power applied, centre connects to other side.
DPST - Just two independent switches like SPST.
DPDT - Just two independent switches like SPDT.
Hope the illustration helps
Ed
Link to comment
Thanks Ed,
That was a big help.  Just to make sure I understand correctly, whey you say...
...By "independent', you mean that you can switch two separate circuits ON or OFF.  They are still controlled by just one controlling coil, right?  So, the two circuits are either both ON or both OFF, right?
Please excuse my ignorance.  I am sort of new to this stuff.
Thanks again,
Paul
Link to comment
  • 3 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
