+/-15V power supply using LM317 and LM337 regulator ICs
Hi Cyw,
Your circuit is correct for a dual-polarity supply having adjustable output voltages from 1.25V to about 27V.
You don't need an input voltage as high as 30V when anything more than 18V will be fine.
You don't need pots to adjust the output voltages when 2.7k (5%) resistors are fine to produce 15.3V outputs. ;D
Thanks a lot~~
I need pots to adjust the output voltage
because it is use for  V reference .....
My AD669 DAC Vref is given by this +-10V
