Jump to content
Electronics-Lab.com Community
Capacitor Size Matter?
stealth17
A larger new capacitor has a better ripple-current rating.
If the capacitor is used as the rectifier filter in a high current power supply, It will have a high ripple voltage across it because its charging and discharging currents are high. A small capacitor will overheat and fail. You might need to use a large capacitor with a higher voltage rating to find one with a high ripple-current rating.
Large old capacitors have about the same ripple-current ratings as small new ones, so don't just select a larger size.
Link to comment
Share on other sites
cool, thanks. Ive read that its not a real good idea in most cases to go over 150% original capacitance. The voltage doesn seem to matter either. Like I can use a 25v cap in place of a 10v cap without problems. Also Ive read that the low-ESR caps are the ones rated for 105c (usually).
Sound all up to par?
Link to comment
Hi Prateek,
Large value capacitors are usually used as filters following a full-wave rectifier in high current equipment. Surges are infrequent but ripple current occurs continuousy, on every half-cycle of the mains. Because the load current is high, the capacitor's ripple current is also high which overheats small capacitors.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
Important Information
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
