Shahriar Posted October 8, 2005 Report Share Posted October 8, 2005 HiI want to build a Digital Ampermetre upto 5A. Does anybody know an IC for this purpose.ThanX in advanceShahriar Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted October 8, 2005 Report Share Posted October 8, 2005 Just use a normal voltmeter IC with a current sense resistor. Quote Link to comment Share on other sites More sharing options...
Shahriar Posted October 9, 2005 Author Report Share Posted October 9, 2005 Dear AlunI am designing a high current Power Supply. If I put a resistor in series with PS and sense the dropped voltage across it, then I have increased the output resistor of my power supply. ???the PS is a SMPS. I don't know whether I can calculate the current from some where else or not?How does Ameter in digital Multimeters work. they can sense current down to 5uA or maybe less. do they use a Shunt resitor or do another trick?ThanX in advanceShahriar Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted October 9, 2005 Report Share Posted October 9, 2005 I am designing a high current Power Supply. If I put a resistor in series with PS and sense the dropped voltage across it, then I have increased the output resistor of my power supply. ???You could use a hall affect sensor that monitors the magnetic field around the conductor if you don't want to increase the output resistance. Another way is to put the current sense resistor in before the voltage feed back loop of the regulator so the it'll compensate for the voltage drop lost in the resistor, you could mimimise the drop in the first place with a very low value resistor and use a mV meter and possibly a differential amp to.Given I'd go for the hall effect sensor but it might be more expensive, anyway here's a diagram to illustrate my differential amp and current sense idea.the PS is a SMPS. I don't know whether I can calculate the current from some where else or not?You could do this in theory but you'll have to take the input into account and it could be complex.How does Ameter in digital Multimeters work. they can sense current down to 5uA or maybe less. do they use a Shunt resitor or do another trick?Current sense resistors are normally used for small currents under 10 amps and hall aaffects are used for large currents over 10A. Normal multi meters use current sense resistors but you can get clamp meters with hall affects to measure 100A or more. Quote Link to comment Share on other sites More sharing options...
audioguru Posted October 9, 2005 Report Share Posted October 9, 2005 A TL071 or TL081 opamp can operate with its input voltages near its positive supply voltage. Quote Link to comment Share on other sites More sharing options...
Ldanielrosa Posted October 9, 2005 Report Share Posted October 9, 2005 Allegro has hall effect current sensors for several ranges. Quote Link to comment Share on other sites More sharing options...
chernobyl Posted October 24, 2005 Report Share Posted October 24, 2005 Could you send me he schematic of this thing? :)...please... Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted October 24, 2005 Report Share Posted October 24, 2005 A hall efect sensor is a module, you don't norrmaly need a schematic, you can buy hall effect sensors from RS componants and probably many other suppliers. Quote Link to comment Share on other sites More sharing options...
ante Posted October 25, 2005 Report Share Posted October 25, 2005 Or, you can just omit the current sense resistor and use the wire if you don’t want the extra voltage drop. Alun’s circuit will work with only the wire as shunt resistor. 8) Quote Link to comment Share on other sites More sharing options...
Guest Alun Posted October 25, 2005 Report Share Posted October 25, 2005 The problem with trying to measure too smaller voltages with this circuit is you'll need a very high gain, and the input offset voltages, both of these factors will increase the error well beyond and acceptable margin. Quote Link to comment Share on other sites More sharing options...
ante Posted October 26, 2005 Report Share Posted October 26, 2005 Hi Alun,If the wire is extremely short it might require a more delicate solution but it will work. I have used 30cm of a 50sq mm wire for measuring the current (0 – 500ADC) with no big problems. I also have had some issues with unreliable hall sensors in the same range of current! 8) Quote Link to comment Share on other sites More sharing options...
